Just a word to the wise about rear brake rotors.
ZiggyF
I have a 2014 RTL that I just did tires, brakes, & the rear rotor. Because of my negligence, the rear inside of the rotor was scoured. Finding a rotor for ABS braking was next to impossible. I found two in Florida, one on Bradenton, and one in Tampa, which was closer. The price was $240.00… not cheap. The ones you see on Amazon say they are correct, but it must be referring to Non ABS systems.
So a word to the wise - keep checking those rotors, especially on the old trikes!!!
As stated above, it is not the rotor but the ABS ring that is important and needs to be transferred to the new rotor. That is unless you are buying rotors that are not meant for the machine specifically... EBC makes them for our bykes and I have them on mine. Just xferred the ABS rings to the new rotors and off I went!
For example:
There is no reason to spend $240.00 on a rotor. The correct rotor is easily obtained from numerous sources. Hypurone is correct in saying that the rotor has nothing to do with the VSS (ABS) system. There is no such thing as a non-ABS rotor for the Spyder.
Not sure where the OP is getting information. But something is a bit off there.
All I can think of is that he may have been having the dreaded yellow locktite nightmare (as we all have at one point) and was trying to find one with the ABS ring already on it? :unsure:
A little heat from a propane torch will get those bolts off easy-peasy. The only rotor’s I’ve seen that have the tone ring attached are used. I hope this easily resolved issue isn’t his problem source.
