Imnotlost
Thanks to DocRiverside and his array of tools, jigs, lifts carts, and laser alignment system, we were able to replace the OEM sway bar, change the oil, adjust the drive belt tension & position and perform a laser alignment.
I must say, the drive belt alignment is not for the faint-hearted - at least on the 2014 model RT. Poor Doc had to re-adjust it 5 times before it finally settled into a good place on the sprocket. I certainly learned a LOT doing all of this maintenance and was quite impressed with the results. The bike tracks perfectly now and riding over the Buckman bridge in Jacksonville during a blustery afternoon ride home, I didn't experience the typical twitchy whipsawing I had in the past.
So, hats off to Doc and many thanks for the hard work and patience he showed when I could never find a tool he was needing!
pps:
Working with stand-up Forum members is always a bonus, because when things don't always go as planned, mutual trust and respect helps to solve problems that may arise....like Dell laptops that eat passwords!, right Doc? :banghead:
It all worked out for the best anyhow, and I am happy to have gone through the learning experience.
Many thanks!
Many thanks!
