Latest BRP Safety Bulletins for Shaft Replacement (2019-12) and Shaft & Sprocket Replacement (2019-13) Recalls - Jan 2025
I'm in Bartlett Tennessee and the dealer near me is FRS Powersports. I called another dealer in Olive Branch, MS which claim to have the parts but only have one tech and many bikes in line for service. When I look at their reviews, I'm just not sure I want to take a chance with them.
FRS is a joke. I dealt with them for over two months and they kept having excuse after excuse that they couldn't get the parts or the right parts to do the recall. I called the dealer in Olive Branch and they set up an appointment with a week, took it to them, and had it back in two days. They only have one Can-Am tech, but they say he is the best around. I had no issues really with them. Good luck.
You had the shaft replacement done there? Thanks for the info and referral.
They are gambling on the science. In Engineering, theoretical fatigue survival is considered once the item has passed 1,000,000 cycles with all the fatige loadings, conditions and part geometries taken into account.
I would assume they'd have done all the Engineering analysis thoroughly in order to reduce their recall costs as much as possible, and have satisfied themselves that the mileage caps represent a fatigue life pass.
In other words, if it doesn't break by such and such miles, then it won't? My trike is well past the mileage cap at 29k.
I thought the same same. If a Spyder has a defective output shaft, then it should be replaced no matter what the mileage is. I think that is a dumb thing for BRP to do to limit the recall to mileage. If any Spyder manufactured within those years, should automatically fall under the recall, no matter what the mileage is. If a output shaft is defective, it should be replaced.
I presume that if the trike is well past the warranty miles and the output shaft snaps, then the trike owner is on their own, am I correct? Is it a repair that can be done, or is it new engine time?
