LIFTING BIKE
Phyllis
Where exactly do you place the lift underneath the bike to left. I have poured over the manual and can't seem to find it. My lift is a side, two plateform lift.:banghead:
By RS balances perfect with the lift going in from the side, placed so that the rear arm is on the back of the frame just before it goes up and over the exhaust. I have some pics I can post up when I get home later if that would help.
Its a bit of trial and error and not in any manual.
Depends..!
on your equipment. With the motorcycle/atv lift you place it as seen above and support it with stands. If it is a single /regular car jack, then place it as far forward on center frame to lift front end and place your stands then as far back to lift the rear wheel and place stand there. If you only have car sissor jack suggest you stop by harbor feight and pick up a jack. Very dicy without one. You can also use auto ramps for the front and then lift rear even with a sissor jack but place your stand...:thumbup:
BRP warns against lifting on the rear shock mount! Don't do it like Lamont shows in his last picture. Place the floor jack at the rearward most part of the frame. That will lift the rear wheel off the ground without risking damage.
If BRP warns against using the rear shock mount, were does one place the rear floor stand?:dontknow::dontknow:
THANKS FOR THE PHOTOS. My brother helped me install the Bajaron Sway Bar and a Bump Skid. We spent quite a bit of time under the front of the Spyder. The lift worked great, as shown in the photo. I will say that installing the Sway Bar on the 2014 was harder than my 2011 was. I have not had a chance to test drive yet, as it started raining and has not stopped. Oh well, This is Vermont!!!!!
It has been pouring here in NH all day as well, but going to clear up tomorrow. Friday looks like a great day to take a ride!!!:2thumbs:
under all three wheels
i put mine under all three wheels and pump.:roflblack::roflblack::roflblack::roflblack::roflblack:
