TicketBait
RT-S PE#0412
10 days later a follow up report on thread #10
Went to ryde the RT Memorial Day like I do everyday, started her up and the engine light and orange
screen saying Limp mode was blaring at me. So I turned her off, and went to my computer to
see what threads had been posted in the past, specific to the RT and Limp mode.
I called my dealership and told them I have had 5300 trouble
free miles so far & they said bring it in Tuesday morning.
Then i started doing more research, and also tried turning the bike on a couple more times to see
if it was just an errant signal, but it still came on.
In the manual it said on pg 149 to have your RT transported in if the engine light is flashing in "LIMP_ HOME"
I learned from these threads how to check the code by pressing "mode" "Set" and the cancel button
for the turn signals simultaneous, and up popped P0524 in the upper left corner of the digital cluster.
More checking and this is an oil pressure sensor. The advise was to have 3 things checked
http://www.spyderlovers.com/forums/showthread.php?t=18955&highlight=pressure+sensor+p0524+limp
I went to bed determined to get this resolved as my wife and I are taking our
first trip together and hotel arrangements can't be changed.
When I started the bike up the next morning, Engine light flashes and Limp home
in lower center of display cluster is orange. I already know I am gonna take it
easy on the bikes RPM's and have planned a surface street route of 14 miles to the dealership.
Well after 1 block of riding and the engine light disappears as well as the limp home
, I continue to the dealership and after explaining everything, they put it on their
computer diagnostic and guess what, NO CODES, nothing in the history, they say
they can't perform all the tests because BRP won't reimburse them. They
are very apologetic and do check the oil level as it is getting close to it's
6k mile change, and said they checked all wiring to the sensor, but without
the fault code their hands are tied. Somehow the code I discovered got wiped
off,. So my question is, did checking the code as described earlier do that??
If this happens again I will have it trailered in with engine running :gaah:
I rode it home and everything was fine. I will ryde it again today, if it does turn
out to just be a bad sensor switch, I lost the opportunity to get it fixed before this trip.
The dealership did not know of the Set/mode /turn signal check. Maybe we shouldn't
either. ok I am gonna go cry now:helpsmilie: If it never happens again then I thankyou
all for helping me fix it
 ray:
ray:ticketbait/steve
