Lots of heat from left side of my Spyder, any ideas?
Yep, it's August. Anything you ride is gonna be hot. If you can, try to find some Baker Air Wings. Mine helped immensely. Other than that, and it sounds crazy, try some leather chaps.
Vented textile riding pants and jacket... airflow is your friend... I just finished a Texas Panhandle to Florida trip and back. Yes, it's hot!!!!
Lots of heat from left side, any ideas?
It would help us a LOT to properly answer your question if we actually knew which year/model Spyder you had @gopher0, instead of leaving us having to assume that it might be an early GS/RS Spyder?? :unsure:
Maybe you could help by following the guidance in post #129 of the Sticky thread below:
There's a lot more good info and help in the rest of the thread tho, so it's truly worth a read. ;)
He did post in the GS/RS forum, so I would assume he has one of those models. If you have one of those models you will have heat from the right side while riding.
If it's from the left side, the exhaust pipe passes close to your calf. Put a wrap on that pipe. I did it and it's way more comfortable now.
Sorry, at the time I had no idea what mod it was.
2009 Can‑Am Spyder Roadster SE5​
I got it figured out now, wear long pants. :rolleyes:
Thanks. Now the tail light is out? Gotta find the fuse box on this thing. lol
Doesn't look like the OP has been back. Maybe he gave up on his Spyder. Wrapping the exhaust helps. Removing the splash covers from the bottom of the bike will also help. Because the hot air is captured insidd of the tupperware with nowhere to go but on your feet and up through the front of the seat. By removing the splash guards that hot air has somewhere else to go and it will make a big difference. This makes it easier to do oil changes as well.
