DR Buck
Spent today adding more options to my 2012 RT Limited and ran into an issue with the right side catalytic converter heat shield. The instructions call for dropping the front end of the brake linkage by removing a clip/pin and possible cutting a tie-wrap. On my 2012 the clip/pin are a single piece and use a cotter pin to hold them in place. This must be something new as the end of the clip/pin where the cotter pin goes through catches on the heat shield and could interfere with the function of the brake. I solved this by cutting an additional notch in the top of the heat shield to provide clearance for the brake linkage to move freely. The picture below shows what I did.
