Bob Denman
Since one of these horns is now a WinterTime project; I'm sure to be emailing you guys with tons of questions!
Would these horns not be annoying, and irritating to the general public. With their very high decibel level ?----Budro
Hopefully !
I installed the horn just like the instruction stated. just like your project. every time I touch the wire to the battery the horn blows. had someone else look at it and he stated I was installed just like the instruction stated. so what could the problem be. don't understand. something I did find out the red wire is hot all the time on the stock horn when you take a tester to it and the - wire black wire is also hot. so when you push the horn button it is neg. to complete the circuit. the horn blows. have any ideas. help.
yes I the relay that came with the horn. tried again as instruction it still blows when I connect to battery. the relay must be bad I guess
and I think I'm going to try Jack's wiring solution, and disconnect the relay entirely and run the stock horn leads directly to the Stebel.
Stock horn location.
Stebel mounting bracket; made of two starter mortor shims
Stebel mounting bracket location
Stebel with bracket
Stebel in place
Relay mounting location before it was tosse din favor of attaching stock horn wires directly to Stebel terminals
