MtlBen
I know there were many reports on the CalSci effectiveness, but I though potential buyers would benefit from the reading below, as it brings up points that I have not seen raised before.
Bike riders can be a tough audience when it comes down to fit & finish. For the ones that will not compromise on these points, pay special attention to points 4-5-6.
1- Delivery
I placed the order on a Friday morning, and I received the shipping confirmation email and tracking # in the afternoon. This was as good as it gets. The box was shipped USPS->Canada Post (I am located near Montreal, Canada). I received the box the following Thursday, which is the usual delay for international shipping. As it sometimes happens with USPS, no custom brokerage fees, no custom duties, no federal/provincial taxes.
2- Packaging
The shield was nicely wrapped in a soft cloth that I reused to store the original windshield, and bubble wrap used to secure it in the box. There was a micro-fleece cleaning cloth, an empty plastic spray bottle and a promotional tire pressure gauge, as others have reported.
3- Windshield size
I ordered the XL, since I am 6'4" and ride on a BRP RT comfort seat that makes you sit a bit higher than on the stock seat. I was able to comfortably look over my 2011 RT original shield so I wanted the same size. The 2 shields are the same size, but the CalSci's holes are 1/4" lower, therefore moving it higher by the same amount. The CalSci shield's top edge is also more straight, compared to the more "pointy" stock shield, so it adds to the feeling of having a taller shield. It does not matter much to me, as I have enough downward adjustment left to lower it out of my sight. Shorter riders may experience a different outcome. A 1/4 of an may not seem like much, but it is noticeable. Below are the 2 shields on top of each other.
4- Windshield curvature - Bottom
The windshield curvature is very different when compared to the stock shield. At the bottom, the curvature is less than the stock shield. So much that when you install it, it first touches the bottom center portion of the windshield support (Part 21), then torquing the bolts actually bend it more into shape so the rubber grommets can also touch the support. The shield comes with a warning to not torque higher than 4ft-lbs, but it seems to be enough to bend the bottom portion. Since the bottom center of the support touches the shield with so much pressure, it is bound to dig into it over time due to vibrations.
5- Windshield curvature - Top
The curvature in the area around the top bolts has the reverse problem: the curvature is more that the stock shield. This causes the shield to rest directly on the outer edge of the windshield support. The 4ft-lbs max torque is far from being enough to "flatten" it so here again, the support is bound to dig into the shield plastic. These marks should remain invisible, as they are hidden by the front screw covers. The other drawback is that since is does not rest flat on the windshield support, you can now see the square holes used to mount the front screw covers.
6- Edge Polishing
The top and side edges are sanded and have a very nice, smooth finish on par with the OEM. It is not the case with the bottom portion of the shield, where you can fell and actually see the rough cut. Same thing with the edges of the center hole, which were also left unpolished. The roughness of the center hole cut is not visible, but it shows on the lower edge without any special lighting.
7- Fogginess
Some users have reported having received "hazy" shields. It is not my case. I rode both in cloudy and sunny conditions, with both the sun overhead and straight into sunset and have not seen any kind of haze in the shield.
8- Ride Quality
The ride is definitely more relaxed than with the original shield. Buffeting is definitely reduced at highway speed. The "back pressure" pushing forward on our shoulders when the shield is raised is also practically gone. A tiny bit remains, but nothing like before. I only had 2 rides that were long enough to effectively test the shield, but they were both in very calm wind conditions, so for now I cannot comment on the sudden airflow disruptions caused by the side winds with the stock shield. Below are the Before and after pics: (Note that the slight tint difference is due to the photo exposure, not to the windshields)
The verdict: I tend to favor function over looks, so this shield does what I bought it for: reduce the buffetting that gets tiring over long rides.
I do appreciate quality products, however, and in this department I have mixed feelings about the product. There are cosmetics "shortcomings" that are only visible from up close, but I am also a bit concern about longer term wear and tear.
The original, full-size 12 Mpixel photos can be found here: http://bchauvette.smugmug.com/Forums/Spyder-Forums/22362150_fb2wtC
...Ben...
1- Delivery
2- Packaging
3- Windshield size
6- Edge Polishing
7- Fogginess
8- Ride Quality
...Ben...
