My Rider Backrest Modification has really helped!
Elqueso2
Hey there! Had a few folks ask me about the backrest on my 2023 Spyder RTL, so I thought I'd share what I did. I hated where the backrest was hitting my lower back and found it to be most uncomfortable. I have a friend who owns a machine shop and had him modify the bottom of the tang. He increased the slot by 1 inch exactly (do not go over 1”) and he also had to take off a 1/4 of an inch from the bottom of the tang. Because of the curvature of the backrest mount at the bottom, it will not seat properly without taking at least a ¼” off. Also, I found that the 2 screws on the back of the backrest for adjusting the seat height plate will dig into the seat a little. To alleviate that, for now I just used electrical tape to cover the screw heads and stop them from tearing into the seat. All I can say about it, is what a big difference it made and it’s so much more comfortable.
Added note: remove the back part of the front seat and unscrew the 2 cap head screws where the tang slides into them. Put Blue Loctite on them. Slide the tang back into them and tighten them enough so that the backrest slides back in with a little effort. I just slid the backrest in and out until the screws were at the proper tightness without any slop. Don’t put the backrest back in until the Loctite has cured. This will alleviate the backrest from moving around side to side and this makes it feel a lot more solid when you lean into it. Hope this helps.
