So I went to install the Scorpion alarm and power bus from Evoluzione today an I actually had issues with the one I thought would be easy :
I had the dealer install the 12v power outlet, they put it in the trunk in the standard manner. So when I got to the point in the instructions where it said to find the 12v wiring it was hooked up already. The instructions state to disconnect it but I am not sure how that is done. I pulled on the back of the power outlet a bit but did not want to force anything. So my question is how/where does it disconnect? Do I just pull the entire rubber boot off that I feel or do I pull that back and then disconnect the wires underneath. I never saw what it looked like before it was hooked up
On a side note the Scorpion went in very easy with the harness. I did not put the ignition kill module in yet, that one requires splicing so I am holding off until I see if I like the alarm
Any input appreciated
