stmike 1800
Installed a altimax rt 43 rear tire ,piece of cake (son has a good tire machine ). Adjusting the belt though is a pain in the rear,what bone head engineer designed the adjusters ?
First, when changing a tire correctly, the adjusters do not normally need changing. Leave the belt alignment alone.
Second, once you know how they work and how to adjust them, they work very well and easily.
for those wanting to see a tire change without changing the belt alignment or tension watch this.
www.youtube.com/watch?v=MWtbQPdKd8w
Which size did you use? I'm looking at the 215/60 15 of the same tire.
So, did you get the tracking taken care of? I know exactly what you went through. For some unknown reason there are times you can reinstall the axle exactly where it was before the tire change and the belt will track differently.I like the video ,will give it a try next tire change.
JC are you still using the "lower" belt tension?
If so can you tell me what value you have it set for? I have a 2018 F3L.
Thanks, Rick
I had the OEM tire it was changed @ 5,824 miles. I am now running the General Altimax RT 43 tire ( 2nd one installed this past winter.BTW i could not believe how thin the old worn kenda is ,feels as thick as a balloon in the center.
