Mike, do you have pictures of that mod in one of your albums?
JayBros, thank you for that assembly information. By putting a little Windex on the rubber gromets I have always been able to get them to go in fairly easily but have never paid attention to the sequence before. My grommets are getting old and chewed up and I need to replace them.
BTW if you are having trouble keeping your rubber grommets in place when replacing that panel, I wrapped mine with a small zip tie to hold them and squirt them with Windex to aid in the slipperiness. It evaporates quick, leaves no residue, and doesn't hurt the rubber.
Are those the ANGLED KNOB - blk plastic pieces that go into a rubber grommet (and are a *itch) to assemble??? If so, I have four of them that I removed from my 14 RT and replaced with a small nylon block, so that I now use a reg machine screw to hold the panel ..... Mike :thumbup:
I've had my side panels off and on I don't know how many times and I haven't had any issues with them. I spit on them to easily pop them back in and I've never had them break off or otherwise come loose unless I pop them off.
The part number for the Angled Knob is 705003746. There is a separate security tool you need to remove the broken part and install a replacement. To avoid breaking the knob when reinstalling the panel, first spray the rubber grommet into which both knobs fit, then insert the angled knob into the grommet, and, last, flex the upper panel itself to insert the straight pin, the Knob, PN 705003842 into its grommet.
Glad for you. I didn’t do this. One of the many techs I had working on it did. But my question was do you know where I can get replacements?
Here you go, I think. The parts page is a little hard to read. Thank Bert, he posted the page below.
https://www.canamseadooskidooparts.c...es-side-panels
https://www.canamseadooskidooparts....nd-accessories-side-panels#:~:text=7845,$5.09
Let us know how the installation went. Did you order thru your dealer?
My dealer Adventure PS got their storm damage fixed and phones and power restored, and called me to let me know they had the bent post in stock for $5!
Changing it out was very easy:
1. Remove the side knee panel. (YouTube has plenty of vids if you need one.)
2. Use a security T20 torx bit to hold the outside chrome piece in place, use a 12mm (exact) or 1/2” box end (close enough) wrench to remove the post from the chrome cap.
3. The original post appeared to have some loctite or something white and sticky on the face that contacts the panel to prevent turning, but I didn’t have any I thought suitable so left it off. Screw the new post back onto the silver cap, making it somewhat snug, but not tight. The post wants to start crooked due to the coarse threads, but it will straighten itself as it tightens.
4. Use the security torx to turn the assembly so that the bent post tip is pointed as closely as possible at the straight post across from it. The bend should be parallel to the edge as shown. Holding the post still with the wrench, tighten the torx head enough to prevent the assembly from easily turning.
5. Spray some windex into the rubber grommets.
6. Slide the very front of the panel under the black cover up by the mirror, then align the bent pin directly in front of the grommet and push straight towards the middle of the bike, not forward like that portion of the panel faces. Push in the same direction that the straight pin is facing. The windex “lube” should make this easy.
7. The straight pin should be easy to push in now. Some people have posted that flexing the panel a bit helps. I did not need to do this.
8. The bottom post probably already seated itself, but if not, push it in.
9. Re attach the four T30s holding the panel on, the frunk black panel, the mirror, and the wind deflector.
Pics below. Sorry if they are rotated, trying to post on my phone.
On our 2014 RTS, those posts and the plastic side panel are keyed in proper alignment when installed correctly.
Should be a tab on the panel and the post is irregular shaped to only correctly align in one position.
