No Customer accessory circuits on 2026 F3 Ltd? Where/how can I connect accessories?
Billaswell
I have recently bought a 2026 F3 Limited Special Series and there doesn't appear to be any customer accessory conecters. The book still says there are 3. So how would you connect up accessories? I did connect a Healtech Thunderbox, but is not working properly. It is intermittent.
Any suggestions would be appreciated.
Thanks in advance.
According to SlingMods, this video is accurate for 2024+ F3 Spyders. Right side inside of the A-arm. Plus, it looks like a pretty neat connector setup for powering more than one. And even though the video says something about a 5 amp limit, your owners guide states the customer accessory fuse is 10 amps. See if this fits what you have and your needs.
I just verified on mine to be sure (F3T 2024). It's where they said on mine
Yep... They've been slowly removing all customer accessory points... For 2026 they are all gone (found that on my 2026 F3-S, also).
You either wire it directly to the battery with a fuse (which is not switched power) or use the connector on the right side behind the battery, which is there only to connect the signature led light... Now the connector is kind of strange (some kind of Delphi/GM connector used for thermostats) , ordered the plug-n-play connector from sling-mods but you need to be careful of what you connect there as it should be rated 5A amp only... I'm going to wire my GPS there, so it shouldn't be a problem...
For BRP I would say, get that 10.25" beautiful display to work properly as a GPS or let us plug our GPS units the way it used to be.
Try this again 🙄 found this connector at Advance Auto that connects to the accessory plug found behind the battery (right hand side behind the A arm. Confirmed this is there on a 2026 F3-S so most likely on other F3’s but may already be used for accessories on Limited’s etc. Advance number is PTA1007. Works for me just adding one accessory.
Not sure why pic is so big 🤣
For 24+ the GPS power connector is still where its always been, left side, rear of the fuel tank, below the seat and behind the body panel. Just FYI, the wiring harness provided is plenty long enough to re-route the connection up under the dash where the old customer accessory circuit was.
I can guarantee it's not on mine (2026). I know where it is, I hooked my GPS there on my 2018 model...
Not for the 2026, at least for the European model... Just the signature light plug on the front, right side behind the battery.
About 10 years ago, I started adding a power relay for accessories. Tapped into a wire for the signal to energize the relay after the engine is started. That way all the battery power is available for starting, there's no parasitic drain on the battery, & it doesn't mess with current draw on the CAN-Bus system. At the time, the Customer Circuit was 5 amp. I used 20, 30, & 40 amp relays depending on what I was installing; most of the time dual Bad Boy air horns, so 30 amp relays. Typical 4 pin relay with a water resistant socket. Attached is a hand-drawn sketch of the circuit.
Its there, I just installed a GPS unit and mount for an owner recently on a 26. Exact same location as on my 24, and my 15 before that.
I believe you, but not for the Euro model, which has some wiring differences from the US/Canada models... We have the low-beams as the auxiliary lights and some hideous orange rear turn signals...
