O M G Please don't beat me, but . . .
Chiisai
I have a, ummm, tire question. I have a 2016 RT Limited and am replacing my 2 front tires. - I've read here in the forum about the Federal Formoza FD2. I can't find a stock size (165/55/15) for this particular tire. My question before I buy, will the 165/50/15 be sufficient or can I go to a different size. Seems like the Federal Formoza FD2 is limited in the sizes on a 15 inch wheel.
Thanks in advance for not beating me up too bad on a repeat subject. :pray:
WON'T BEAT OR EVEN LIGHTLY SLAP YOU - HaHa
This tire is not well known here, but may well be the Best performing tire now available .... the Vredstein Quatrac 5 - it comes in these three sizes that will fit your Spyder - 145/65 r15 ....155/60 r15 .... 175/55r15 take your pic , they may be hard to find ,but it will be worth ..... try Tire Rack.com ................. Mike :thumbup:............If you get them ( or any car tire ) I highly recommend a front psi of 15........:thumbup:
Reviews?
Blueknight911, any reviews on this tires? How do they handle in the curves and in rain? Mileage on a Spyder?
They sound like a great tire, I just had not heard anything about them.
I am running 175/55R15 Federal Formoza AZ01 on the front and like them a lot. I think the FD2 has an updated tread pattern. Only have about 5K miles on them so not enough to even show any wear......
I'm running Hankook Ventus and they are the ****. handle great, ride is real smooth and traction is fantastic
https://www.tirerack.com/tires/tire...88969&ef_id=WiiUCwAAAFm6a0LE:20180415021936:s
Tire comparision
Since you obviously use / like the Tire rack tests ........... Look at the Vredestein I mentioned above and compare ..... Now how much do you like the Ventus ??????........and another tire is often said ( here on this Forum ) to be EXCELLENT , Yoko "S" drive .....see what they score at tire rack.com ....Mike :thumbup:
I have the Federal Formoza AZ01 in stock size. They handle very well. Good traction dry or wet. I've got over 5,000 miles on them and no sign of wear.
