Odyssey Which PC680 ?
eddieshep999
I Have a Spyder RT -S SE5 2010 Model
I am thinking of upgrading my OEM Battery and having used Odyssey batteries in the past
I would like to fit one of them
I understand the PC680 is the correct size but I have the following questions
There is a choice of 2 - See below
Odyssey battery PC680MJ Size 186mm x 81mm x172mm (A Little bigger than the one below)
Odyssey battery PC680 Size 179mm x 75mm x 165mm
Both are rated with the same specs but the Odssey PC680MJ Has a metal jacket for increased heat and vibration resistance
There is not a lot of cost difference between the 2
Which one would be more suitable ref the size needed to replace the Original Battery
Do I need the Odyssey battery 90 degree (L Shaped) terminal adaptor pair to Convert the vertical terminal mounts of the Odyssey battery to horizontal mounts
Can I disconnect the OEM Battery to fit the Odyssey battery without upsetting the onboard electrical systems - or is there any special procedure
I need to do - I am concerned that the Spyder may throw up some fault codes
Will the system reboot itself and will any previous settings I have made ref Radio channels stored etc have to be re-entered
Thanks
Eddie Sheppard
Reading UK
