3wheeldemon
I am very interested Tom, I gave up on waiting for the back-ordered cables and I am going to do it myself. I will like to reproduce the factory setup as much as I can.
Thanks!
3WD
Thanks!
3WD
Thanks!
3WD
3WD, here is what the official Se5 Ground Wire Warranty wiring it looks like.
If I am not mistaken, somebody in one the forums explained this in layman's terms, but can't find it.
Cheers.
You are still not well grounded. The oil cooler attaches to the oil tank mount, just like the coil itself. The oil tank is rubber mounted. You need to add the long wire to the frame to get a good ground.I did my home-made coil fix yesterday, only from the coil mount bolt to the oil radiator mount bolt (G1).
Rode my SE5 today and it seems to shift a little better now, and no sticking in reverse or 1st, although it might be somewhat early to declare the fix a success...
My title question still stands: Why two ground wires...? :dontknow:
Cheers.
it was BJT post #7 from this thread:
http://www.spyderlovers.com/forums/showthread.php?p=129566#post129566
I also recommend you see post #22 of this one to see the "official" setup:
http://www.spyderlovers.com/forums/showthread.php?p=132155#post132155
PS: Getting any cooler in Maracaibo (I mean below 100F)?
Saludos!
3WD
Hey 3WD:
Thanks for the reminders. I'll install the longer ground wire soon and then see if things improve.
Getting any cooler in Maracaibo in mid-August...? You had to be kidding me...
You know how it gets... Even in December, when locals refer to the 'hielitos' (winter ice), temps still may go from 85 to 100°F...
Saludos, Pilo
P.S.: Never got another e-mail from you. Did you get my answer to your first one?
... Like Lamonster said once: 'ground is ground..., right?'
Saludos, Pilo
