Oil Change Question
vampyregirl
I'm going to be attempting my first oil change on my Spyder soon. Do I need to put the bike onto jack stands to do this, or will the garage floor do?? I realize I will have more hand room underneath if it's on stands, so this is really more of a survey as to what other folks do!!!
I would vote for the jack stands, if you have the ability to do it. Also, change out the drain plugs, to hex head, while you're at. You won't be sorry. There are several different types with stronger magnets available, so do search here. Good luck.
I usually put a floor jack at the sweet spot that brings the spyder up fairly level, secure it and drain the oil.
It's easier that way.
I guess I am just out of the norm because I do it just sitting on the floor. Seems to have plenty of room for me. This on my SM5 RSS...
Agree...
:agree: I like to do it on the floor...Works fine I can even nap while the oil drains though I do warm it up a bit for a faster drain...:thumbup:
Thank you for the input!! I'm thinking as long as my oil drain pan fits under it, I should be good to go. And sleeping on the job could work as well!!! :roflblack:
FLOOR LEVEL
Before you make a REALLY big mess, do you have any 2 x 6's .....you can easily drive the Spyder up onto them ....even doubled.....and that alone will get it 3 inches higher...........Remember the PAN may fit, but can you get your hands between the Spyder and the PAN and work ???????...........good luck..................I love a DIY'er.......Mike :thumbup:
Roll the front wheels up on ramps. Easy...
Sent from my Nexus 6 using Tapatalk
This how I do it also. To get it level I use a floor jack to bring it up level then slide another ramp under rear wheel. It is easy, and there is still room for napping:D
