However, my main concern is the magnetic bolt on the clutch side… it had a decent amount of shavings on that as shown.  Am I in “oh *****” condition?
Also, I may not have been diligent about pre oiling all of Ron’s replacement O rings.  Is that critical?
What shavings!! :shocked: nojoke
That's nothing to really stress yourself over. Sure, it's
some shavings, but that's not much in the overall scheme of things and it doesn't look like anything that you should be really concerned about either; besides, your magnet wasn't covered with 1/4" of thick 'fur' that was actual filings, nor was it covered with big bits of something clearly critical; so you probably should be worrying more about the oily mess you made on the floor! :lecturef_smilie:
Check the magnet again next oil change; maybe even take photo's & compare them... Better yet, get an oil analysis done - have you kept any of the oil you drained out?? If so, get an analysis kit & send it off; and when you do the next oil change, do it again - grab a sample mid-drain and send that off. Then compare the results! It's really the
TRENDS in these oil analysis & other things that reveal the most insight, be they from the comparison of any pics you take; or any oil analysis you might get done! A '
once off showing of minor shavings evident' occurrence doesn't really tell you too much at all - after all, that
little collection of shavings could simply be from the thread on plug itself; or maybe from it or something else being tightened down a bit more than usual... :dontknow:
For
THAT sorta shaving load on the drain plug, with no other indicators or concerning evidence to suggest any issues, and
especially if this is the first time you've really looked for shavings &/or the first 'proper' oil change that you've done on the bike, then apart from those suggestions above, there's really only one thing to do...
See my sig line; Follow the directions there-in; Rinse; and repeat repeatedly!
hyea:
Ps: While it's definitely 'best practice' to pre-oil your replacement 'O'-rings, it's no major biggie if you didn't,
especially if you don't have any leaks evident after you've run the bike for a while. So for that too, see the last para above! :thumbup:
