Just got my new 2021 RTL and I have a oil leak in the same area. Dealer thought it was the oil plug but after driving home about 8 or 10 miles oil all over the bottom by the exhaust and drain plug. I did follow the oil all the way forward to a rectangle aluminum block bolted on the right side of the engine mid way up the front. Its hard to tell what the wind has done to the oil flow. I wiped it all down and went on a 4 or 5 mile ride and the oil is on the bottom of the engine again. I have less than 100 miles on it. I will follow this post and report any fix when they find it. I will check my oil to see if it is over filled. I "assumed" the dealer already did this.
My dealer is 90 minutes away, and I know they would have it for a week. So if I could find a bad oring on a dipstick I would not be puffing my chest out demanding someone fix my warranty issue. It's great that you would. But that is part of us being individuals with there being no clear cut answer without considering the whole story.I have never taken a vehicle to a dealer voluntarily. But if I spent $20,000-$25,000 for a new vehicle and something appeared to be wrong,
and I was not an experienced motorcycle/Spyder mechanic, I would return it post-haste.
Man if they have a engine ready to send you that will take some time then removal and installation.
If no engine in stock then I would ask for a loaner until they get yours fixed or replaced??
Ok, the air box is clean and dry. I sprayed simple green on everything to see if this will help as I ran out of brake clean.
Thanks for the help and recommendations LOL as Im just frustrated. I can see above the alt and its dry around it as nothing is wet on top and around the oil filter area, but the filler tub is hard to see but looks dry. If the secondary air box( throttle body) is dripping oil this would be exactly where it could be coming from but cannot get me hands near it.
I'll keep everyone posted, and I'll re check the oil too!
Thanks again!!
