Hi guys,
Any idea on what can cause this type of pattern of leaking oil? This accumulated over the past month. No visible leaks on the engine but the lower frame is all oily. 2008 SE5 RS. 6000 mile service was done 2 mo ago, including valve adjustment, and the problem started after that and is getting worse. The bike has 7500 miles on it now. The only mod is a catch can routed back to the airbox, that was done about the same time as service. Air box is clean. It also is hesitant sometimes now on warm starts. It would get to 600-800 rpm and then die. Cold starts are OK. Thank you for your input.
