Oil - why would you use Rotella T6, a diesel oil, in your Spyder?
I noticed people talking about using Shell Rotella T6. T6 is diesel oil, according to what people mentioned. Since when and why would you use diesel oil in place of a4 stroke motorcycle engine oil?
Diesel oils normally do not contain the slickeners that are added to oils which are recommended for cars that promote greater MPGs. Those slickeners will not work well with wet clutches.
:agree: ..........and it's JASO MA II rated ..... doesn't get much better than that .....JMHO .....Mike :thumbup:
the last 20 years of my working life , was as a Diesel Mechanic , Big Trucks , 18 wheelers .. the ONLY Oil we installed was Rotella T . but back in those days I never heard of anyone putting it in anything except Big Rigs . . . just saying .
Simple, as it meets all the specs of the over rated BRP oil. It's readily available and about half the price. It's worked fine for me in my previous 998 and the current 2021 1330's.
Have been using Rotella T4 conventional oil in 7 Motorcycles over the last 12+ years. Have already bought 2 gallons of T6 15w40 for use on the first oil change on the F3-S. Not saying it’s the best there is out there. Just saying that it has the correct specs, is (usually) readily available, and has never failed me in the years I have used it.
Rotella T6 is great oil. I have used it for years. It's also in my Jeep and even my lawn tractor
WHY NOT??? IT's JASO MA2 rated. Good for MCs with wet clutches and cats. Good for a 9K run too, according to my analyst's reports. That's due to the heavier additive package that Diesels require for engine longevity. That benefits gas engines too.
I guess I will just stick with Valvoline Full Synthetic 10w40 Motorcycle Oil. Putting diesel oil in a bike just doesn’t sound right
Because if they called it Shell Rotella T6 Motorcycle Oil you would be very happy, but truckers would avoid it. Who has the biggest market. It just happens to meet the requirements of both.
It's been known for years by HD riders that diesel oil could be used in their engines in a pinch if they were caught out in the middle of Egypt somewhere and couldn't find MC oil.
Even when they put gummybears, on the package, It won't make a difference.... or if they would call it motorcola, it's all about the specs, and Rotella t6, just ticks all the boxes.
Jaso MaII rated is well suited for the spyders, it's been said above, it's all about marketing, but rotella is a good oil, is it the best? I don't know, there will be better ones around, even overhere in the netherlands Rotella is readily availble.
The spyder has a wet clutch, using the wrong spec oil, would ruin the clutchplates in a heartbeat, I've seen it happen.
Oil Specs
:chat:...If the oil you use meets the Spyder specifications, then you are good to go. Rotella T6 (a diesel engine oil) just happens to have the correct specs. ....:thumbup:
Been using Diesel motor oil in in my Goldwings for over 30 years. Yummmm!!! hahahaha
Tim
Why would anyone care or worry about what oil, tires, windshield, boots, socks, or underwear I use unless of course they're paying for it. Rotella meets the specs. End of story.
I go so far as to say they don't even have to be in Egypt or in a pinch. When I had my v-twin before getting the bikes I have now, I ran T6. Its used a lot on the forums I used to frequent.
A lot of people on the 2nd gen Vmax site use it in their bikes. It is also a go to remedy for the modern coyote engine (5.0 or 302) in the newer mustang and ford truck engines that have the known "type writer tick". I have not tried it in either of my vehicles, but I have heard good things about it.
