Max LTD
Hello everyone,
The now 8 years old battery (YUASA) is completely dead in my 2014 Spyder RT Limited (Checked and confirmed). OEM battery replacement is not available for another 2-3 weeks. Consequently, I found this Canadian Tire Motormaster Eliminator Battery which I believe would fit and work in my 2014 RT.
I was wondering if someone would review these specs to make sure I am not mistaken:
Web Page Link: https://www.canadiantire.ca/en/pdp/...ated-powersports-battery-etx18l-0271566p.html
MOTOMASTER ELIMINATOR AGM Factory Activated Powersports Battery comes factory filled, sealed and charged - just install and ride
Premium AGM technology provides high cranking power, performance and durability
Ideal for Motorcycles, All Terrain Vehicles (ATV), Utility Vehicles (UTV), Snowmobiles and Personal Watercrafts (PWC).
Use the car parts selector to find the battery for your vehicle
Longer life and faster recharge time when compared to conventional flooded batteries
Sealed and spill-proof – does not require fluid top-ups and no messy or dangerous acid spills
Maintenance free - Never requires filling of acid or water
Extra vibration resistant to withstand one of the leading causes of battery failure
Low-self discharge rate ideal for seasonal use
Replacement for CTX18L (FA)
Specifications - Volts - 12 ; Amp Hour Capacity (10 hr) - 20 ; Cold Cranking Amps - 340 ; Weight (lbs) - 18
Dimensions: 8-1/16" L x 3-9/16" W x 6-3/8" H (205 x 90 x 162 mm)[/B]
Thank you very much!
