Our 6x12 enclosed trailer set up for our Can Am Spyder S2S
NutinElse2do
Our 6x12 enclosed trailer setup and road trip to BajaRon’s is finally dialed in.
After completely overthinking every single step of this process, we’re now at a point where everything is set up and, most importantly, we’re both comfortable with it.
Here’s where we landed:
  • Tongue weight at 425 lbs, 13% of loaded trailer @ 3300 lbs
  • Trailer weight under the RV’s limits
  • Etrack Wheel chocks in the front to prevent the wheels from turning (Clearance is tight)
  • Front tie-downs to the shock eyelets (Thanks Baja Ron)
  • Side tie-downs to the passenger footrest hole eyelets
  • Rear tie-down to the floor
Had to move the cables that help the door go up out by 1” to give us the clearance needed.
We also installed a wireless camera inside the trailer so that we can keep an eye on everything while traveling. We are guessing at least 7-10k miles.
We’ll be heading East from Arizona in our little RV, pulling the 6x12 trailer across to the East Coast, with a stop at BajaRon’s and plenty of rides along the way.
Looking forward to the Tail of the Dragon!
For anyone who is looking to make a 6x12 trailer work, here are some pictures.
View attachment 254079 - View attachment 254080 - View attachment 254081 - View attachment 254082
Looks like you are good to go!
Only 1 other thing, make sure you stop and reset your trailer clock at each time zone you cross!
Safe travels.
You have done a great job on that trailer setup!!! There's no doubt in my mind that you could flip it upside down and the bike would still be hooked down to the deck!!! Good job! 🙃 I can tell you that you are going to LOVE the riding in that area, and you're going to know your bike a lot better than you know it now!! Ron and all of the guy's and gal's at the shop are the best!! Have fun, and keep it between the ditches.
Could you post a picture of these. I did not see where an eyelet could be attached.
We used 8x30mm 304 eyelets, with a spacer in the passenger footrest holes. These are only snugged down not tight. More of a fail safe type of thing.
Hope this helps
Thank you very much, we have been stalling on the mileage so Baja Rons can install his shocks and give her the first service. I am so looking forward to the riding in the East, Arizona is great, but nothing like mountain roads to get to know our Spyder.
