It is understood if you leave your exhaust stock and change the air intake to something like the Kewl Metal intake, the EFI system on the Spyder will compensate. Likewise, if you leave the intake alone and add a less restrictive exhaust, the EFI has the ability to compensate.
However, I am contemplating JT's new air filter and cat bypass along with my existing Two Brothers muffler. Needless to say, this combination will significantly lean out the stock EFI.
When looking at the maps available for either the PCV or Juice Box Pro, none of them deal with a wide open intake and exhaust. So here's the question. Does anybody have a map, in either PCV or JBP format for a :spyder2: which has had the intake, cat, and muffler replaced to a less restrictive design???
