Bamajohn
Well-known member
From old threads, it seems that this is a known issue: BaJaRon posted in 2022 the following:
"A more common problem than would be expected. Once the piston detaches from the threads, it's a bear to get it to re-engage. As you have discovered. You have to apply a good deal of pressure to collapse the very strong spring behind the piston. Unfortunately, this is difficult to do with the caliper attached to the brake line. The threads are fine so the piston needs to be perfectly mated, flush with the threads to avoid cross threading them.
It seems that the adjustment has little if any reserve run-out. So that when the pads are worn too much, the piston disengages on its own.
As discussed, you may need to remove the caliper to give you the ability to apply the needed pressure. If you do. Raise it up so that you drain as little as possible from the system. This will make bleeding easier.
Good luck."
This happened to me Sunday on my 2020 Spyder RT Base and I'm asking if anyone knows of a used caliper for sale or an in-stock caliper, Please PM me.
My brake pads were Very Thin, but not bare metal and the piston won't retract (BaJaRon's tool, clockwise). Caliper is on my work bench, but I have a week-long trip on July 5.
Thanks in advance for any help.
Good luck."
