Rear Speakers on a F3 Limited not working - anyone else? Any fix?
AY4B
I was syncing my new Zumo XT with my audio system today like in Lamonster's video and noticed I had nothing coming out of my rear speakers. Has any one else noticed this and what is the fix to get them working? Went through the menu and all it has is a setting for speakers on or off.
I also raised the rear top box to look for loose wires and found none that I could see.
I assume they worked before? Check the fader on the radio...might have gotten set all the way to the front.... beyond that, might be a fuse if the rear Amp is separate from the main radio which I believe is the case on the 17's.
There is speakers and headset not on off. I think your audio fader is set to front. Go into bass, treble balance, fade settings. Then use fob to go to rear.
I always assumed they were working until yesterday when I put my ear right on the rear speakers and did not hear anything while the fronts were playing loud. I looked for a fader and all I could see in the settings is speakers on or off. I then raised the rear top box and could see the radio box and an amp box. Both had large wire harnesses connected to them but I could not tell which ones went to the rear speakers. At that point I just put everything back together and decided I'd just post a thread to see if there was any easier solution before I went any further. I was getting everything ready for my Ozarks ryde this weekend and I had too much to do to get into it any further till I got back.
I also had another issue when connecting power to my new Zumo XT. The power did not work on the place that I had my 590LM connected. I posted another thread on that issue and someone said it is powered through the radio. I now just have the XT powered through a different Accessory wire on the left side, but it will only work with the engine on. I wanted key on power. These 2 issues may be related now that I think about it.
Just went out to check, there are no fade controls on the 2017 F3 Limited, only bass and treble, speakers on and off. Next is the Fuse for the rear amplifier. I have no idea where that is located. I spent one day looking for it and no dice.
When I was looking to add the top box on my 2016 F3T, I got the information that when you add the rear amp & speakers, that you have to have it programmed at a dealer with BUDS.
Maybe yours is just missing that programming?
On my understanding, if you don't have any fade adjustment from the controls, maybe it has never been properly programmed.
I'm having the same issues.My rear speakers do not work and I can't figure it out there is no fader switch for this system . Only an on and on and off speaker switch , this is sucks
Tommy, the post your looking at is 6 years old!
Mag Yukon hasn't been on the forum since Feb of 2025
Knowing what year and model your bike would help a lot! If it's a new model you have to get into your preferences screen and fix it from there, you can change the balance to front to back!
2016 F3T
It is at the fuse box underneath your front frunk.
You need to make sure you have the rear amp under the top case. The 2016 F3T did not come with the rear top case nor the rear amp.
Also check to make sure that the speakers are connected to the amp/wiring harness underneath the top case and the passenger seat.
Spydel
I have a 2016 F3T that does not have a rear amplifier. Also, I am going to tap into the wire loom for the front speakers and put them on to the back Speaker's, or do you have to put an amplifier in?
