Is there any way to install another add on to make getting air in the rear tire easier?
When it comes time to replace your rear tire .... before the new one is mounted .... add an Angled steel Mtc. stem from " Kurveygirl " , about $10.00 ... I have done this on every Spyder I have owned. .... The first one I removed the old valve and patched the hole .... then I just left the Oem valve, and put the new one opposite it..... The new one should be put on the other side of the rim,( the disc side )and away from the raised part of the wheel so tire machines won't hit it ..... Mike :thumbup:
I have wondered if it would be possible to fit a valve into the side of one of the spokes, pointing directly outward. This is done on BMW machines and would make inflation much easier.
...you can use an air chuck used for airing up dual tires on a truck.
Until you can get your air valve moved or if your somewhere without the right sizes chuck, gonto the Harley store and get a stem extender as used for an Ultra. Harley has the same problem and have 6" flexible extension. Costs about $10.00. I keep it on the Spyder with my air gauge.
This is one way to cure the problem like others have said.
That's what I use.
My issue isn't so much airing it up but getting the valve stem in the small area where you can actually access it. This is one of the reasons why I got the FOBO 2. I don't want to have to move the bike forward inch by inch (releasing and resetting the parking brake, running around to the other side of the bike, repeating the process, etc) before every ride. I check the FOBO and call it good.
