Rear tire air valve
On a side note, I was riding yesterday in 45* weather and my FOBO alarm went off. I keep my rear tire (still a Kenda :( ) @ 26#. FOBO was screaming at me that it got to 31.2#. Not sure why it was so upset although that did seem to be quite a bit of increase considering the ambient temp. I was less concerned with that than I would have been had the pressure dropped. According to FOBO, it's now back down to 26.5#. I love this FOBO app. :)
An 'over-pressure alarm' like that will occur because too much pressure increase may be an indication that the tire is under-inflated for the ambient temps &/OR for the riding you're doing, and the pressure in your tire has risen too much from it's cold start/base setting.
Depending on the system, these 'too much increase' alarms can be triggered by the actual pressure increase, or by the temperature increase that effectively causes the pressure increase in the first place - either serving to warn you that a rise like that might be due to a slow leak in the tire lowering the volume of air inside it sufficiently to be a risk (obviously not the case here, or it would now show a lower pressure!); or that the material/layers the tire is made of are at risk of 'de-construction' due to the increase in the tire's temperature.... albeit, you're probably not quite at that stage with just an 'almost 6 psi' increase from cold - but then again, if it increased that much fairly quickly, maybe so?! :dontknow:
But you also need to consider what you were doing in the 20-30 minutes of riding immediately beforehand - if you were riding 'somewhat more spiritedly' than usual, that temp increase & the consequent increased risk to your tire might simply be due to that 'over-exuberance', and if you slow down & the alarm stops as the tire's pressure/temp returns to its normal range rather than showing a lower than normal pressure, then that's probably what it was, altho.... if you were here in Oz, you'd also need to consider if you were riding on a hotter road surface, or if that tire was more exposed to sunlight, but considering where you are/the ambient temps you report, there's probably not too much of a risk of either of those.... there again, it could be that your FOBO was responding to a temp/pressure increase that was largely in the valve stem itself, and not actually in the tire?!? As I've mentioned before, it does sometimes happen with these end of valve stem sensors - warnings or pressure changes being reported that other devices can't detect any reason for, and that (sometimes) seemingly 'self correct'....could've been due to quite a few things, and unless you can identify anything that was clearly different in the conditions or what you were doing/how you were riding at the time.... :dontknow:
That said, it's been a while, but I thought the FOBO system allowed you to set an upper & lower pressure or temp limit for the alarms, altho most systems do generally have default limits - often about 4psi.... :rolleyes:
If you lose air when checking tires, as I did, Slime puts out a digital "no air loss" tire gauge. I have one and it works great.
Yeah, I was kind of thinking if you're losing a couple psi when checking the front tires, or rear tire, then either your gauge or your
technique need some serious work. Those front tires aren't that small.
But I also agree that the Slime digital gauges are first rate. I have three of them, and they all work a treat.
Try this...
Here's the TireTek gauge I use for all three tires: https://www.amazon.com/dp/B01KAHVJ8Y/ref=cm_sw_em_r_mt_dp_tbo.Fb5X1TQ59
TireTek has a very similar tool to attach to an air compressor. It uses a flip lever to lock onto the valve stem and allows you to both add and release air pressure without removing the tool:
https://www.amazon.com/dp/B01AO1ZBLW/ref=cm_sw_em_r_mt_dp_sio.Fb0Y4BN4M
Yes, I do usually have to kneel, front or rear. Generally I can see enough of the rear wheel to guesstimate where the valve is and find it easiest to reach when it is between 3 and 6 on the clock.
I've had both of these tools for more than 3 years and no problems with either one.
OR; you could spend maybe $2 at a bicycle shop and get a 90° stem adapter and just leave it on all the time. Being made for bicycle tires they are rated for over 100psi. I've had one on our 2014 RT since the first week of owning it. Now a little over 7500 miles later--no problems whatever.
RYOBI makes a nice small compressor with a built in gauge and a clamp on to valve stem. This works perfectly for all tires up to 125#.
Jack
Simple fix
Is there any way to install another add on to make getting air in the rear tire easier?
Next time you have to replace the rear tire, do this, before removing the rear tire
mark the wheel on the other side of where the current valve is, now 180 degrees
from that valve drill a new hole for a new valve that is closer to the edge but not where
the new valve will hit anything now install a new metal valve or rubber valve, Yes you will
have 2 valves in the wheel it's no big thing and it works very well.Just be sure
you put it across from the old valve stem so it don't cause any balance problems.
When I had car tires mounted on the front, I had them install longer valve stems. The made checking and adding air much easier. I don't know why BRP uses such short stems. Maybe they are two cents cheaper.
For those of you using the FOBO TPMS, what did you do to make their sending units fit on the short stems. I fond some short (1/2") extensions but was worried about stress to the rubber valves.
thanks johnv
thanks johnv
They seem to work fine on 2019 RT. Can't speak to the others but mine are pretty short. I do not use the supplied locks, can't see a need for them.
thanks johnv
They work just fine on my 2021 RT base. No issues, whatsoever.
thanks johnv
I think that for some obscure/indecipherable reason, BRP used shorter valve stems on some of the F3's outta the box (2017?? :dontknow: ) and those were a bit tough to fit the FOBO senders onto! :shocked:
No biggie tho, when you toss the Kendas & get some proper tires fitted, they'll probably hafta take the valve stem out anyway, so just get the tire fitter to use the next longer length valve stem then - no worries after that! :thumbup:
That said, the valve stem extensions won't be seriously stressing anything - and if they do cause issues, it'll just highlight that you already had a problem that needed fixing anyway! :rolleyes:
:clap:I just ordered a pair of these 90 degree stems from Amazon supplier. Anxious to install. It's a huge pain to even check the rear tire pressure!:popcorn:
:2thumbs:90 degree brass stem was easy to install and makes Pressure Checks and adjustments sooo much easier. Best $$ spent in a while!:clap:
I'll try to post a photo soon.
