A 5-sided freakin' nut?? Why in the name of all sense would anyone do that except to force the owner to either purchase a special wrench or to force him/her to have an authorized shop do the work?
I have tried the park f6 tool and a crow bar. That funny nut not moving. Is there anything else I can use? What am I doing wrong ughhhhhh
Is it a reverse thread maybe? :dontknow:
Yes. Put a large wrench on it and turn.
More like a big A__ crescent wrench slimmed down to grip the flat width of the pry bar that is stuck into the slot of the regular threaded nut.... if you do this more than a few times, grind a custom fit piece of flat stock about 1/4 inch thick to fit...View attachment 169479
Are you using a cheater bar? If anything, go to Home Depot and buy a 3' piece of metal plumbing pipe and use it to lengthen the wrench. Make sure the bearings need to be replaced. After I did mine I found the OEM ones were fine.
Okay, so the picture above shows the Park Tool FR-6 in place. View attachment 169486
Now, I'm understanding the issue better.
Why not use a breaker bar with the right sized socket on it? Or, as mentioned, slip some steel pipe over the socket wrench handle to provide additional leverage.
I still don't understand how you would use a wrecking bar to turn this nut...
There is no 5 sided nut.
And, how does this grip the nut?
....first the pry bar trick is for those of us too cheap ( I mean frugal) to get the right tool....then when the Park tool is out of the way or not available,,
just hold the flats of the pry bar in the slots of the retaining nut like GranPot says... helps if you hold your mouth right.. and use that big Crescent wrench
to twist whilst you hold down to keep the pry par ends engaged in the slots... Well on second thought probably you should just go buy the right tool and
the proper socket along with a 24" breaker bar and get after it:thumbup: but like others said, don't change it if you dont have to...
We have put over 40 K each (76, 44, 46, 40) on four different bikes, and always feel and spin the bearings when we change tires, and havent changed a bearing yet...I do have a set on the shelf waiting![]()
