GaryTheBadger
Thanks Freddy...that's exactly what I was looking for!
Follow-up question: Where you call for three O-rings 15IDx3mm, I can only find two of them in the BRP on-line parts catalog (two of that type, one of the other type, three total O-rings) What am I missing?
Resurrecting an old thread...
Spyder needs a new rear tire and it has 23K miles. I also need an oil change and I was going to order the filter, crush washer, and whatever bearings I need from our new sponsor, Honda East Toledo.
Should I go ahead and do the wheel bearings at 24K? How much money roughly for the part(s)? What parts would I need to order?
Thanks in advance,
David
I've read this whole thread which started way back, but didn't see any ref to U.S. made bearings. Has anyone come up with anything they can share? I'd like to get a full set, with seals, for sprocket and wheel and have them on hand.
I should have read the manual and had mine done at time the rear tire was installed but didn't, so my question is; does these bearings give some "warning" noise, or other indication, before they fail entirely? Its not something I could do and its gonna be a long time before another rear tire is needed. I have nearly 17K on the RT, and 6K on the tire.
We have China tires on the Spyder now so I'm not sure we don't have China bearings too. I have stock and these coming so I'll let you know.
The BRP bearings are made in the USA. BRP switched over in 2009. All models use the same part numbers.
I now have 48000 miles and they are fine ,they were stock BRPi just bought them for a 2011 rt-s rear wheel bearings, seals and oring. for $69.00. when i took the rear wheel off icould spin the sproket bearing, but could not spin the wheel bearings so i took it to the dealer and he replaced them under warrentee. 11,500 miles
