Rear wheel squeek still present
Sopher
I dont think its the e-brake pad.
Would wd-40 help if I carefully spray the axel barrings?
Or would dry graphite powder be better?
The sqeel is constant now.
Sealed wheel bearing can't be externally lubed. See your dealer.
After re-aligning the drive belt, I had a squeak and a click. Drove me crazy. The bearing are new. So I check the large axle nut. I had tighten the nut to much. Unlike a castle nut, ours don't have the slot the set the carter pin in. So I just backed the nut out until it just touched the carter pin. Checked the belt to make sure it runs true. No more speaks or clicks.nojoke:chat:
