elkk
On a friends 2008 RS SE5 - when in gear the front drive sprocket is not turning, but the bolt (and shaft) is turning. So either the shaft splines or the front sprocket splines are worn down or gone. I am trying to remove the front sprocket bolt with an air impact gun but before I lay in to it I need to know if the bolt is reverse thread? Does the bolt unscrew clockwise or counter clockwise? I need a DEFINITE answer. HELP Please ASAP Thanks
*** RESOLVED - SEE PICTURES BELOW ***
4/10/15
Today we decided he had nothing to loose so we ground the weld off around the bolt being careful not to destroy the bolt head, hit it with the impact wrench and bingo, off it came
. Luckily the output shaft is nearly perfect, the splines on the pulley are completely gone. Still can't figure out why someone would weld it instead of replacing the $100 pulley, oh well. Ordered a new pulley, washer and bolt today. He should be back in business soon. Thanks for your all your replies, ideas and well wishes. I certainly learned alot, again I say it sure gives you a good feeling to accomplish what you thought impossible.
FYI I can assure you the bolt is standard thread, right to tighten.
4/10/15
