In that pic I don't see the antennae ....where did it go ..... most folks slide a 7mm deep socket over the antennae ( remove boot first ) then hold the socket with a vise grip pliers and un-screw it ....... it may not come out easily BRP uses the largest amount of lok-tite in the known Universe ..:roflblack::roflblack::roflblack:................MikeI am working on installing the BRP arm rests on our 2016 RT Limited.
I’m not sure how to remove the antenna.
Do I just remove the bolt and tiny nut shown in the photo or is there more to it?
Thanks for your advise......brian
What you can't see is the large metal block that the Antennae is screwed into .... Don't un-do those bolts/nuts because the metal piece won't fit thru the antennae hole...... If the antennae is after market ( ie shorty ) you will have to separate the two plastic parts and as stated be very careful ........... What exactly are you trying to accomplish in this Thread subject .....knowledge is power and a good way to get better answers ........ Mike :thumbup:Here are some more photos.
When I removed the boot, it looks like either a square nut or the square body of the antenna body....not sure which.
I found this in a two year-old thread:
SPYDER RT:
1. REMOVE THE OEM ANTENNA BY FIRST PULLING UP ON THE RUBBER BOOT AT THE BASE OF THE ANTENNA.
2. USING A SMALL LOCKING PLIERS GRIP THE BOTTOM BRASS PIECE ON THE ANTENNA AND TURN LEFT TO REMOVE.
3. CLEAN THE FLAT SURFACE AROUND THE THREADED HOLE WITH A CLEAN RAG AND RUBBING ALCOHOL AND LET DRY. SEE FIG. 1.
4. TAKE THE NEW RUBBER GROMMET FROM THE PACKAGE AND PUSH IT INTO THE HOLE ON THE BODY PANEL AS SHOWN IN FIG. 2.
5. REMOVE THE SET SCREW FROM THE PACKAGE AND CLEAN THE THREADS WITH RUBBING ALCOHOL. LET DRY.
6. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE THREAD NEAR THE END OPPOSITE OF THE HEX SOCKET.
7. INSTALL THE SET SCREW INTO THE ANTENNA MAST AND TIGHTEN WITH A 3MM ALLEN WRENCH. SEE FIG. 3.
8. PUT A SMALL DROP OF REMOVABLE THREAD LOCK ON THE EXPOSED THREADS OF THE SET SCREW.
9. CAREFULLY INSERT THE MAST THROUGH THE HOLE IN THE GROMMET AND THREAD IT INTO THE THREADS IN THE SPYDER. SEE FIG. 4. HAND TIGHTEN.
10. YOU MAY NEED TO SLIGHTLY ROTATE THE GROMMET AS YOU ALIGN THE SET SCREW WITH THE THREADS IN THE SPYDER.
Bob,The 7mm socket trick doesn't work on the new "Shorty" antennas.
But Lamont posted the most excellent video about it! :thumbup:
You just have to find it... :dontknow:
I have a 2014RTS-SE6 and I replaced my original ( long antenna) to a short antenna.Here are some more photos.
Boot/ Short AntennaI discovered I could leave the antennae attached to the brass mounting block, and detach the mounting block from the speaker housing. This allowed the antennae to flop around enough to get the Tupperware off.
thank you everyone for your suggestions!
.....brian
turn the antenna to the right like your tightening it and pull up at the same time. It's on a spring that tightens when you turn left. Lamonster garage has a video on it.
