Right low beam on F3 burned out - should I replace both headlights?
JimH
I have LED headlights (from LaMonster) and yesterday found out my right-side low beam is not working, high beam does. Left side works fine, I had these lights 4 or 5 years. Is the recommendation to replace both or only the affected side (right)? I know you buy headlights in pairs - I am not looking forward to removing all the panels to install them. Thanks in advance.
Jim
Having replaced the same light MANY times, it seems the right is the one that always burns out. A few years ago, I started only replacing that light. I saved the other bulb for when needed, but it will most likely go into the right one as well. I seem to replace the right every 1 & 1/2 to 2 years.
I think that the 'if one of your Headlights goes, replace them both' thing is more of an incandescent or filament type light issue - if they're both on the same circuit, and one filament (or resistor) in that circuit fails, then the other one will be subjected to increased load/heat, and so it's likely to fail pretty soon too!! :cautious:
It's not quite the same thing when it comes to LED's - my understanding is that they don't really work as 'resistors' in the circuit, so one failing doesn't increase the load on any of the others in the circuit, and so shouldn't shorten the expected life of any of the other LED's in that string - but there IS the 'expected life' in terms of 'hours of operation' to consider! But if you haven't run your LED headlights for thousands of hours/exceeded their expected life, then unless it's an overall 'poor quality' thing, one failing should be just a 'statistical likelihood' event, without any real impact on the other/the rest of the LED's in that string/circuit. My thoughts anyway, and I've replaced a few single LED's in a circuit without issue (not yet, anyway) on that basis. :sneaky:
Happy to be corrected if I'm thinking about all this LED stuff the wrong way, but my understanding is that when working, they don't singly or collectively add up to a great deal of resistance in the circuit; and losing one out of a pair or many won't mean any significant change to all the others... So you should be good to go replacing 'just the one', at least if you replace it with another LED of the same or similar quality, capacity, & manufacture anyway?! ;)
Yes this, plus filament globes tend to yellow & dim as they get older. If you just replace one at a time then you'd have mismatched headlight brightness.
I just spent a few minutes with Google, which suggests an LED headlight will last between 30,000 and 50,000 hours.
Using the 30,000 number, if you ran your LED headlights 12 hours a day, 365 days a year, they would last a little over 8 years.
I don't think I'd worry about replacing the one that's still working.
I don't think I worry about replacing the one that's still working.
That life number is under optimal conditions; it doesn't factor in things like the road vibration and on/off cycling. Many electronic failures happen during the start/stop cycle. A filament bulb like a halogen or incandescent bulb, cannot take the vibration, however minor in the Spyder, and I wouldn't get a year or so life. After switching to LED head - and fog - lighting, we have yet to replace one (although we certainly don't ride as much these days).
Slightly off topic: Household incandescent lights will typically fail when turned "on". In my house, I'm replacing LED bulbs well before the stated lifetime. And that's in an air conditioned environment with no vibration. CFL lights were a lot worse, and in many cases, no better than incandescent lighting.
