A
arntufun
Guest
This thread might take a few seconds to load because of all the videos.
This video series will take you through the breakdown of the Spyder from panel removal, airbox/filter removal, rear wheel removal, brakes, plugs, wires, coolant, oil changes, exhaust gaskets and more.
This 1st series of videos will show you how to remove the left and right side panels, top cover, locate the battery and remove the rear tire splash guard.
This 2nd series will show your air filter location and remove the airbox. Follow instructions above for panel removal.
This 3rd series of videos will show you how to remove the rear wheel. Please see Lamonts RS rear wheel removal prior to viewing these. Link here http://www.spyderlovers.com/forums/s...eel-Removal-RS
This 4th series of videos will show you how to install a Battery Tender JR to your Spyder. Follow the 1st Series of videos for left side panel removal.
This 5th series of videos will show you how to install a piece of foam in your airbox line to prevent oil from getting into the airbox. Follow instructions for left side panel removal and just watch the 1st airbox video in series 2.
The foam is from a dirtbike air filter so you will have to get one of those to do this install.
