RS/GS: Tie Rod end question
Motavar
On the front GS/RS Tie Rod. Is the nut at the end of the tie rod part of the ball-joint assembly (is it welded on) or is that nut loose?
I'm looking at mine right now and it sure looks like its part of that ball joint or something, I cannot tell.
I looked in the service manual and in diagram 7 part 19 it doesn't list the nut as being by itself. It just shows the tie-rod going into the whole ball joint. Confused :/
ahh never mind. I just torqued on it to see if it would move and it did. So the bolt is separated from end (which makes sense). It just didn't look that way with all the debris on the nut.
