eddieshep999
With having to remove the Mirrors on the RT everytime the tupperware has to come off they seem to get more and more loose
it also seems that the can be removed with little effort and could be prone to being removed by vandals although they would have to know
the sequence
BRP Sould have come up with a more friendly version - The fittings are prone to being damaged just in normal on/off operation if care is not taken
Having said that I wanted to make my mirrors more secure and less prone to shaking whilst riding
This is what I did
I removed the mirror having marked at the bottom edge where the mirror fits against the bodywork - near to the Headlights
I drilled a hole in the bodywork to take a Cable tie (Zip tie in US)
I drilled a hole in the RT Mirror at the bottom edge so the 2 holes would line up once the mirror was back in place
A Cable tie was threaded through the bodywork then though the mirror - Once the mirror was back on the Cable tie was pulled tight
this secured the mirror to the bodywork - The cable tie sits below the mirror and is not noticable from the front but can be seen under the
Mirror (The excess cable tie is cut off)
When I want to remove the Mirror I just cut the cable tie and replace it with a new cable tie when refitting the Mirror
The cost of a Cable tie is alot less than the cost of a replacement Mirror
As with any modification Photos help to explain how it was done - So here are some and I hope it helps other who may want to secure their Mirrors
Eddie Sheppard
Reading UK
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
Sport Tall Wide Clear Windshield
Utopia Backrest
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
the sequence
This is what I did
Eddie Sheppard
Reading UK
List of Mods :-
HMT - Brake Light
Utopia Backrest
Grip Puppies
