tbohman56
One of the problems with finding a front tire for the Ryker is the rim width of only 4.5 inches. (PPA rims on Slingmods are a 5" rim). I have found only one tire that is a possible solution, the Achilles ATR-Economist 165/50R16.
Specs are All Season, V Rated (149mph), Load Range XL, Load Index 77 (908 lbs), UTQG 400AAA, rim widths 4"-6". Made in Indonesia. Very wide range of prices from $48 - $71.
They are .8" wider and .4" shorter in diameter than the OEM Kenda's, so you would probably have to do a fender delete. I think you could replace the running lights and turn signals with the TricLED Dual Color light strips (Gen2).
Now .8" doesn't seem that much wider until you look at them side by side. I believe the 165 is the same width that the F3 uses.
For some a fender delete would be an automatic no go, and it may be for me too.
On one hand the Kenda's have not been a bad tire for me, my ride with the BaJa Ron bar and end links is really rock solid even at high speeds. But, I do have the right tire wobble on sweeping left had turns, and I do notice a slight right hand tire deformity as I am rolling down the road.
So, for all you Spyder riders that have some experience with car tires, what are your thoughts?
