shunkmanitu
My SE-5 has experienced several shift failure incidents.  The first occurred yesterday during a 2/3 throttle stoplight launch and attempted 3500 RPM shift to second gear.  I pulled over to the side of the road and found the transmission  locked in first gear.  The shift button had no effect either up or down.  Only after I shut the Spyder down and allowed it to reset and then restart did it again function.
Again today after steady running at about 37 mph in fourth gear it failed to down shift as I came to a stop. This was about three miles into a sedate ride. I was lucky that I had a place to pull off and again cleared the system. Spoke to the Tech at Pensacola Motor Sports and he said he has had the same problem reported on another SE-5. Apparently the analysis showed no failure code on the other machine and he has no answer from BRP as yet.
As I returned home and turned into my subdivision it again required shut-down/reset to get back into first and restore normal function.
