DynamoBT
Got the Spyder out this morning after a pre-ride check. Tire pressure was not to what's recommended here. Fired up the compressor and pumped 'em up. Had a bit of a snafu thinking my headlights were out. Checked the relays. A OK. Come to find out the lights come on when you start the engine. Duh!!!
Went directly to a parking lot. Set up my cones (cut in half tennis balls) per the owner's manual. Practiced for about an hour. All I can say is that idle RPM's is higher than I'm used to. I know this is normal. First exercise with no throttle and clutch only was an education!! Soon I was weaving all over the place. Practiced emergency stops from 2nd gear. Swerves. My brakes got to squealing pretty good during practice. They shut up once I was out on the road ryding.
Rode a short loop that I knew from my early motorcycle days. No Problems whatsoever!!!! On the motorcycle I would often feel my heart in my throat I was worried about so much. Not the Spyder!!! It was pure JOY and Lovin' it every minute!!!:2thumbs:
Came back home to have lunch. Going to go out again and ryde to my dealer (1 hour each way) to have it inspected. Called them this morning to order a few BRP goodies. I'll have all installed including the CHAD when they come in. Yeah, going to drive up there twice in short time. What a tragedy, huh???
Had it up to 60 so far. Vibration is my main issue. Think anti-vibe bar ends are in order.
I am absolutetly absolutely ecstatic I found the Spyder to ryde!!!! This thing is GRRRRRRRRRRREAT!!!!!!!!
