and a Quart and a half later...
Thanks for all the replies. Went to Walmart and picked up a quart of the best stuff they had: Mobil 1 Racing 4T 10W-40 Full Synthetic oil ($9.97). Before adding any oil, checked one last time with the Spyder at normal operating temperature on flat level ground and there was absolutely no sign of oil on the dipstick. Added half a quart of the oil, let the Spyder idle again for a few minutes, checked oil again, still no visible sign of oil. Added the remaining half a quart and repeated the same process, still no visible sign of oil on dipstick. Another trip to Walmart to purchase another two quarts of oil this time, just in case. Added another half quart and that finally did it. Oil appeared slightly below the full line. Finally!
I will ride it today and see if this resolves the shifting issues and will certainly monitor the oil immediately after each ride today to see if the readings are consistent.
....stay tuned for the results
