NEW oil leak 2016 RT - anyone recognize it/know what it is from?
Baird4444
I have had an oil spot on the garage floor just every once in a while. Went for a nice 75 mile run this AM while it was cool then parked it. Went out late this afternoon to run an errand and found this JI-GUNDUS oil spot, right of center.
Anybody recognize this spot?
FYI I did top up the oil a couple hundred miles ago, so I don't think an overfill would take this long to belch out. I plan on jacking it up in the morning for a look when it's cooler. Just hoping someone would say "Yup, I've had that, and it's ....."
What year and model? Bear in mind the bottom of most Spyders is a series of panels, where it appears to be leaking from may well be a long way away from where the actual leak is.
The best approach in my mind is to take off all the bodywork/Tupperware and start looking in places with a flash light. I'd start looking at where sensors plug into the engine, oil line connections, evap canisters, etc. depending upon the year and model.
2016 Spyder RT limited... Yea, I was hoping someone say "oh heck, check your oil filter cap..."
Assuming your oil filler cap is on properly and your oil filter is hand tight, I'd look to see if your evap canister which is part of the emission control system isn't full up with oil. The sensors that plug into the block, o-ring seals, all the usual things you would check on a car.
Did it have a recent oil change, where oil can get on the top of the underbelly tupperware, and later continue to drip out?
Did have a recent oil change, or didn't have a recent oil change?
If it DID have a recent oil change:
1. Go through the proper procedure for measuring the oil level to make sure they didn't overfill it. There is a procedure as it's a dry sump engine.
2. Make sure it's not leaking from the oil filter in case the housing wasn't seated or tightened correctly.
3. Take it back to the place that did the oil change and make sure they just didn't spill oil everywhere when they filled it.
If it DIDN'T have a recent oil change, take the plastics off and start looking for a source of the leak with a flashlight. If it's enough oil to run over a bottom panel and leak onto the floor, the leak should be obvious enough.
Oh, heck check your oil filter cap!! ;) The trouble with the RT is that with the engine wrapped up like a cocoon a drop of oil down in the belly pan will go anywhere. Like said above, if it keeps on dripping you are going to have to open that side of the bike and do a little snooping around! If nothing else you'll be able to give it a good cleaning!
Right after I bought my F3 I thought I had bought a leaker, nope, it was the filler/dipstick cap. Mines got a bit of a tight spot before it's actually tight which made me assume it was tight when it wasn't.
Assuming that you have been using the correct method of checking the oil level.
And Assuming that you have not done an oil service recently.
And Assuming that you replaced the filler cap correctly.
Then you're stuck with what has been suggested. Lift the Spyder, take the splash panels off and start looking. Don't be surprised if there is a good deal of oil hiding in the splash panels.
If only we could slide a hose on, put the other end in a catch pan, then open a valve! In the mean time I stuff paper towels around the hole in the panels to "try" to capture the wayward oil draining out.
If you take off all the side panels and investigate with a flashlight you might be able to determine where it’s coming from.
Before you remove the underside panels just chuck down a couple of 40lb bags of clay cat litter. You can use the cat litter that’s not soiled to soak up any oil on the top of the underneath panels.
It works just like oil-dry. When you’re finished sweep up the kitty litter and drop it off at the recycle center.
Good Tips have been Posted Above.
Remove all the Side Panels and with a very bright light inspect the engine and transmission. This will give you an idea of where the oil leak might be.
Next get some spray-can oil cleaner and clean off the oil. Next start and let the engine run while checking for the oil leak. Remember to use your light.
I have found that within 5 to 10 minutes you will find the problem.
Make the necessary repairs and then check it out again.
If you're not able to do this. I guess you will need to take it to a Dealer.
Good Luck on Your Mission. (y)
Answers... I've got answers!
I took it back to the stealer as I had a warranty, a 5.5 hr haul on the trailer.
It seems that where dipstick tube connects was the culprit. Will be next week waiting on parts,
a half a dozen O rings and seals. It could have been worse, I'm convinced.
I want to thank ALL for their suggestions - Mike.
So Glad that you a fix for your oil leak problem. Hopefully this dealer will fix and then check again. Here's to a good repair and a permanent fix.
Enjoy your Spyder Ryde Times. (y)
