Pretty much what's been said. Pull with inside arm while planting the outside foot and to start, slow in and fast out of the turn. Accelerating through and out of a corner is more confidence inspiring compared to braking late into a corner.
That's absolutely the way to go!!
hyea:
Altho with the '
much better than anyone else out there' braking our Spyders have, you can still be heading deeper in towards the corner at a faster speed, braking later; doing all the planting outside foot and the pulling yourself in & down on the inside bar; and then due to enhanced stability & steerability of the Spyders over most other things, get on the gas much sooner than anyone else and get out of the corner quicker and earlier too!!
Btw, 'trail-braking' too often &/or for too long on a Spyder is
NOT recommended - the Nanny
REALLY doesn't like it at all, and if you do use that technique too much/too long, you not only risk over-heating your otherwise pretty damned good brakes and causing brake fade, but you will most likely eventually end up in Limp Home Mode! :banghead: But you really don't
need to use that technique with the Brembo Brakes and the greater stability our Spyders have!
hyea:
Also, you really don't need to be treating everything as a race-track to do/practice any of this slow in/fast out - use your body more - brake late/accelerate early stuff; in fact, it's probably better to practice it all at slow and steady speeds
A LOT before you even start to think about upping your speed...
IF you ever really want to! However, that said, it never hurts to do all your practicing and then once you're comfortable with the whole process, every now and then, when it's safe, just give it a little more speed and practice it a bit faster again to build your knowledge & confidence! Even if you never plan on riding that fast in the normal course of events, and you never even exceed the speed limit &/or a 'comfortable speed for you &/or your pillion', just
KNOWING that you
CAN and that are not only capable but also practiced at it is a great confidence builder for all the rest of your riding!
And then if you ever really need to call on all this in a critical situation and maybe hafta go even faster than you ever have before, you KNOW you've got this and that you CAN! :lecturef_smilie:
Similarly, I strongly recommend that you, at least every now and then, when it's safe and you have a clear road to do it on,
practice your 'Emergency Stopping'!! nojoke
There's no denying that, since the release of the 2013 Spyders with Brembo brakes all round, and when ridden the right way, these Spyder things
WILL brake a helluva lot better and stop a helluva lot faster than just about everything else on the road, if not
ACTUALLY better than faster than
absolutelyfreakinlutely everything[ else on the road!! But if you look back thru the older threads & posts here, you'll find more than one person complaining about their brakes, and how they failed to work as expected and they just sailed on past wherever they were trying to stop/whatever they were trying to avoid! Exactly the same thing happened when ABS Brakes first came out - people didn't realise that they not only
COULD stomp on the brakes and stay stomped on them to get the ABS working properly, but they
SHOULD!! And instaed, they were either doing a half-hearted 'stomp', or lifting off immediately the odd/different noises & things started happening! :gaah: - The 2010-2019 RT's with footplates even have a '
drop-away footplate' feature to enable this 'massive stomp' and if you ride one of them but have never braked hard enough to cause that footplate to drop away,
then you REALLY SHOULD try it AND PRACTICE IT!!
But be warned, brace yourself well before stomping hard on the brake - then brace yourself even
MORE!!
These things can & will stop VERY HARD AND FAST when you do!! :lecturef_smilie:
You really should practice this stuff all the time, even if you never actually plan on riding that hard &/or fast; or braking all out like that ever!! You just never know when you might
need to be able to do it well, safely, and with skill!
Just Sayin'
