Here is the entire spec list, sans the individual group headings, from the Build It page.
 			Download spec sheet
[TABLE="class: table table-stripped table-bordered specs-table-expandable table-desktop"]
 					 						 						[TR]
 	[TH]Type[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Rotax[SUP]®[/SUP] 900 ACE™ in-line 3 cylinders, liquid-cooled with electronic fuel injection and electronic throttle control
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Bore & Stroke[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  2.9 in. (74 mm) x 2.7 in. (69.7 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Power[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  77 hp (57.5 kW) @ 7100 RPM
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Torque[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  56 ft-lb (76 Nm) @ 6300 RPM
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]Type[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Automatic (CVT)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Reverse[/TH]
 	  	 		 			 			 				 				 					 						[TD]
[/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]Front Suspension[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Double wishbone
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Front Shocks Type / Travel[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  KYB HPG with preload adjustment 36mm / 6.38 in. (162 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Rear Suspension[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Multi-link - mono swing arm
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Rear Shock Type / Travel[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  KYB HPG 40 mm with remote reservoir 4-positions compression adjustable damping and preload adjustement / 6.89 in. (175 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Electronic Brake distribution system[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Foot-operated, hydraulic 3-wheel brake
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Front Brakes[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  270 mm discs with Nissin 2-piston floating calipers
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Rear Brake[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  220 mm disc, 1-piston floating caliper
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Parking Brake[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Park lock
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Front Tires[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  MC145/60R16 66T
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Rear Tire[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  MC205/55R15 81T
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Aluminum Front Rims[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  5-spoke Carbon black & Machined, 16 x 4.5 in. (406 x 114 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Aluminum Rear Rim[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  5-spoke Carbon black & Machined, 15 x 6.5 in. (381 x 165 mm)
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]RIDER CAPACITY[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  1
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]STORAGE CAPACITY[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  1.85 gal (7 L)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]TOWING CAPACITY[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  N/A
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]FUEL CAPACITY[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  5.28 gal (20 L)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]FUEL TYPE[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Premium unleaded
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]L x W x H[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  92.6 x 59.4 x 41.8 in. (2,352 x 1,509 x 1,062 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Wheelbase[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  67.3 in. (1,709 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Seat Height[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  24.2 in. (615 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Ground Clearance[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  4.4 in. (112 mm)
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Dry Weight[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  627 lb (285 kg)
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]Type[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  4.5" digital display
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Main Functions[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Speedometer, tachometer, odometer, trips, gear position,  distance to empty, engine lights, fuel gauge, clock, ECO mode, Sport  mode and Rally mode.
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Audio System[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  N/A
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]SCS[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Stability Control System
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]TCS[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Traction Control System
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]ABS[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Anti-lock Braking System
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]DPS™[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  N/A
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Anti-Theft System[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Digitally Encoded Security System (D.E.S.S. ™ )
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]HHC[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  Hill Hold Control
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
 					 						 						[TR]
 	[TH]Factory[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  1-year BRP Limited Warranty with 1-year roadside assistance
 [/TD]
 					 				 			 		 	   [/TR]
  [TR]
 	[TH]Extended[/TH]
 	  	 		 			 			 				 				 					 						[TD]                                  BRP’s B.E.S.T. extended service term available from 12 to 36 months.
 [/TD]
 					 				 			 		 	   [/TR]
     					 				[/TABLE]
