I have never been a fan of torquing spark plugs. The gasket makes a good torque reading difficult (and sudden). I don't recommend you follow my lead, but that has always worked for me. Be sure to choke up on the ratchet, especially with aluminum heads. If you do torque the plugs, sneak up on the setting, as you should when torquing anything. For 14 lbf-ft, go 8-10 first run, increase to 12, then do the final torque to 14.
Those plugs look a bit rich down deep, but the tips are lean (most recent operating range. I'd say you still have some adjustments to do in some ranges. Keep in mind that it is very diificult to read plugs with today's engines and today's fuels. Lean engines burning part ethanol gas don't leave much color. It is also very difficult to do the reading right, for the most part...running full throttle then cutting the fuel and ignition simultaneously, and coasting to a stop to read the plugs. You can't get good readings at other throttle conditions, either. That is why oxygen sensors and exhaust gas analyzers are in use these days.
