My new RTS had done that when I first got it several times. Now have almost 400 miles on it and it only did it once in the last week. Someone said new units have to go thru several tanks of gas to clear out a coating but that never happened on my RS. Is the throttle body something they can check at the 600 mi. service?
As a non mechanical guy what does a throttle body actually do?
To those that know... could turning the throttle while having your foot on the brake also cause this? Just wondering...
Mine has done the same thing and I have the same model year (2011).
In my case though, I could restart it and take off. I don't believe I mess-around with the throttle when stopped. I never was one to do that even with my motorcycles -- but wondered if those with that bad habit could be contributing to the problem.
Just wondering...
That will not do it. Throttle problems on the RTs are related to the components themselves (and sometimes the programming). In this case, we don't even know if that is the cause. The owner needs to see his dealer.To those that know... could turning the throttle while having your foot on the brake also cause this? Just wondering...
Just wondering...
If its a se5 make sure the clutch is disingaging or it will stall at lights
Thanks for everyone's reply.
I have the SE5, although I am not sure I know what you mean about disengaging the clutch... all I do is downshift or sometimes let it do it itself -- so I assume it is disengaged -- although it shows it to be in first gear. I suppose you could put it in neutral each time; but I have a problem with doing that considering the idiots out there at intersections. I would prefer to be in gear and ready to get out of the way, if you know what I mean.
To make it simple the throttle body takes the place of a carburetor.
Sort of... But I know you're trying to make it simple. I've never learned to do that!
The throttle bodies handle the air component of the combustion mixture.
The fuel injectors handle the fuel component (DUH!)
The amazing thing is, with all the computers and years of improvements made, carburetors still work better for some applications. Optimum fuel/air mix is an extremely difficult thing to achieve. Just ask Amal!
Hey, Amals are better than SUs. :roflblack:
