SpyderPops Rocks!
MarkLawson
RT-S PE#0031
I recently installed SpyderPops' “Missing Air Dam”, “Missing Heat Shield” & "AIR MANAGEMENT SYSTEM" on my wife's '08 GS and have been amazed with how well this setup works. I even rode it in 90 degree heat while wearing shorts (I don't generally wear shorts while riding, but wanted to get a better idea of the heat coming from the engine) and was unable to feel any more heat from the right side than I did from the left. I expected an improvement, but not this much!
Temp gauge ran between 3 and 5 bars, depending on driving conditions. Tended to hit the 5 bars while stopped. I saw nothing that causes me any concern.
Harvey (REPOPS), great job & thanks!
:2thumbs:
I have the same SpyderPops products and I love them. Harvey even installed them for me at SiTS last year. :thumbup:
im having trouble puting on the plastac thing on the rig cone thing.it never seemed to fit where i was to rivit on so i left it off any sugestends?im not much for puzles.:yikes::chat:
What about saddle heat, has it helped with that?
I wear full pants, I never have much of a gripe with the right side blower, but the saddle heat gets crazy after a while.
Didn't notice any heat coming from the saddle, but wasn't concentrating on heat from there either. I rarely ride this Spyder (mine is an RT), so don't know if saddle heat is an issue.
If you start where the instructions say & then align the edge of the tape along the edge of the cone, this will provide a 1//2" overlap. When you wipe the activator in the cone and then start to peel the red plastic strip off the adhesive, it sticks immediately & permanently, so be very careful as you go, only peeling an inch or so at a time as youe work around the cone. Then drill and attach the rivets. That piece is essential to block the radiator heat from coming through the 2" gap between the outer cover and the one your knees are against while riding. Keep working with it until you get it. You'll love the result!
thanks ill try it agin i got the air dme on no proulbm,but could never grt that peace they gave me to match up to the funnel thing on the bike.will try agin.:thumbup::D:joke:
As you wrap it around the cone during the test fit, you'll see how it comes together. Be patient with it.
