Magdave
Hi Bob,
Thanks for sharing your Spyder RT heat experiences.
I stopped gas boiling in tank of 2013 Spyder RT-S SE5 in summer 2013 riding in 112+deg heat.
1. A richer fuel ratio, (Len at Pitbull Powersports).
2. # 9 NGK Iridium sparkplugs (cooler running plugs); Baja Ron plug wires.
3. Wrapped both exhaust pipes.
4. Added reflective heat shield over top of exhaust pipe wraps.
5. Installed sticky wrap heat shield all over gas tank.
6. Cat bypass pipes installed (cat removed).
7. Removed air resonator box on left air intake (opened up air flow under left side panels).
8. Removed gas charcoal canister, extended gas tank vent hose with gas fuel filter routed up front,(opened up air flow under right side panels).
9. Installed Lava 1200 deg reflective heat shield in front & underneath Brimbo brake master cylinder.
10. Extended reflective heat shield about 6" out right side radiator exit to block heat from right foot area.
Note: gas cap temps dropped to 116 deg; gas in tank dropped to 128 deg.
I have since put ceramic heat mods on a 2011 RT; two 2013 RT's with success.
Hope this helps some RT owners.
(Jan 29th 2014 I bought a 2014 Spyder RT-S SE6;
Cat removed; 2" stainless steel exhaust bypass pipe built/installed.
I put ceramic reflective heat shield wrap on exhaust pipe to keep heat off engine cases.
The 1330 in line triple has awesome torque/power smooth shifting).
Enjoy your Spyder rydes!!!
View attachment 87515View attachment 87516
Jim
Gas boils at those temps:shocked: I am not going to spend $40k on 2 bikes to solve it when BRP should do it. Why get a '14 if you solved the issues? We have all read the possible help to cool it but it will never get cool enough with out proper ventilation in the engine bay. The jury is out on the '14s lets see what 90 to 100deg weather does to them. I bet they will boil too. The ONLY solution is double walled properly insulated tanks from the OEM along with improved venting from the OEM. It is their problem. We all have tried things that helped but never eliminated it.
