Sway Bar - Help me decide: BajaRon Regular or Ultimate Sway Bar?
Allen42
I'm trying to set up an appointment with SpyderPops when in Hot Springs to have some work done.
I'm getting the headlights and foglights replaced with BajaRon's LEDs, and I think I'd like to upgrade the sway bar, but am not sure if I want the regular or ultimate sway bar. (Will do new linkages with either.)
We are usually two up, but both normal to small sized people. I've only noticed any issues a few times on curves where I have to adjust the steering, and I also do like a little lean. I don't want the bike to feel too hard or unresponsive.
Can someone help me decide which to get?
How many miles have you ridden your Spyder?
How much do you and your passenger weigh together?
How much weight do you plan to carry in the storage compartments?
The Ultra-Bar is designed so that it will not be too stiff for lighter applications. But if you don't need the additional efficiency provided by the Ultra-Bar, you don't need to spend the additional $40.00 or so. Answer these questions for me and I will be able to give you better advice.
The Ultra-Bar is designed so that it will not be too stiff for lighter applications. But if you don't need the additional efficiency provided by the Ultra-Bar, you don't need to spend the additional $45.00 or so. Answer these questions for me and I will be able to give you better advice.
Thanks Ron!
We have about 3-4k miles on the bike since purchasing it. Bike is about 8k miles total.
We weigh about 300lbs together.
Regularly, we'd have maybe 10 lbs in the comparments. (Tire patch inflate stuff, rain gear, and windshield cleaner/rags) For overnight trips, maybe make it 30-40.
Thanks Ron!
The weight of the passenger is more significant (pound for pound) than the driver because they sit higher and farther back on the bike and thus create more centrifugal force. It is too bad that getting a chance to ride with both sway bar systems isn't practical. It is good that you've put that many miles on your Spyder. With 8k in the saddle, you probably have settled into a (what's normal for you) riding style.
Yours is a hard one to call. Normally, I like to recommend the Ultra-Bar for anyone riding 2-up. 2-up riders is exactly what I designed that bar kit for. But at your weight, if you are a leisurely rider, especially on curvy roads. I'd say the Original bar will do you just fine. Thought you don't have to ride like Evil Knievel to appreciate the Ultra-Bar. Nor will it give you a stiffer ride. You may not be able to appreciate the added control with your lighter than average, 2-up riding.
However, if you ever plan on loading up for a trip, (it's easy to put 100 lbs. or more in the RT storage compartments). And especially weight in a top box. Then the Ultra-Bar would be more in your ball park.
Great question. Thank you for letting me pontificate on it! :rolleyes:
Thanks again! I'm somewhat more than a "leisuraly rider", and seem to be getting more aggressive as my comfort level goes up, lol. If it's a matter of both will work fine, and the ultimate won't seem too stiff, the extra few bucks isn't really the deciding factor, so I think I'm "leaning" that way. (See what I did there?)
If you're converting your increasing riding skills into having more fun in the curves. If you just enjoy the feeling going through the twisties gives you. Then definitely, the Ulta-Bar is your better choice. It will grow with your skills where you may exceed what the original bar can deliver. Please call the shop to order. It's the least expensive way to go.
Just as a follow up: I had the BajaRon ultra-bar installed at the Hot Springs rally (by Daniel himself!) this past weekend. IMMEDIATE and HUGE improvement noticed. The bike just generally feels "stable" now. Riding two up on the twisties up the Hot Springs "mountain" was just plain fun! (Maybe a little scary for her, but she's learning, lol.) Even on the straight highway, buffeting by the big rigs, etc. isn't nearly as bad on you expect. I didn't fully believe all the hype, but yes, it's true. Feels like a different bike! Awesome job, Ron!
So glad you are enjoying the ride! That's what it's all about!
I had the same questions and talked with the group at BajaRon. Bought the Ultimate and noticed improvement in first couple of miles. Best decision. Thank you BajaRon.
I just ordered the BajaRon Original Sway Bar (Anti-Sway). Solo rider, 175lbs, no bags. I'm looking forward to installing on my 2024 F3-S in a week or so. I'm hoping for a flatter turning attitude in the "twisties".
I'm in Florida are they still called twisties?
Naaa... Exit/entrance ramps and roundabouts. 😆
Twisties in Florida? I lived in Pompano Beach for 2 years, and the highest point (other than apartment buildings) was the garbage dump. The most challenging "curve" was turning left at an intersection. :ROFLMAO:
Thank you for the map. I'm sure we'll find something interesting with it. San Antonio to Dade City, FL has some picturesque, hilly rides.
Just installed today. Very easy install with clear instructions. Got my Spyder up to the required height with a combination of Race Ramps, floor jack, and a ratcheting jack stand on a deck pier(available @ Home Depot, etc.). The trick is that you only need one side at that height. The other rested on the Race Ramp at 12".
My brief road test was impressive, I can't wait to take it for a real ride and really wring it out.
Had the Baja Ron's Ultra Kit installed on my 2023 RTL last month. Chose the Ultra due to my size (240 pounds with gear on), and plans for future front shock upgrade.
This is a Highly Recommended upgrade. Not only is twisty road handling vastly improved, but the bar and end links make interstate, cross wind, and bumpy pavement riding much more stable and less stressful. The kit exceeds all advertised claims. If you have limited funds and need to space out your Spyder upgrades - start with this one first!
Installed BajaRon's Ultimate Sway bar recently on my 2022 RTL and WOW! What a difference it makes. Feels like piloting a slot car - stays glued to the road! Even my passenger noticed the difference. I am 6'2" and 250# and my wife is 5'10" and 180#. This a heavy load and the Ultimate bar makes a HUGE difference. By the way, I did the install with ramps on the ground and dug a small hole under it to allow removal of the old sway bar. Good instructions.
I'm in business and I need to make money. Everyone in business is in the same place and I'm no different. But I have to say that making customers happy is where it's at. Most of us at the shop ride. And we know how rewarding that can be with a properly set up Spyder. (Or anything that you might be throwing a leg over)
But knowing that you're having as much fun as we are makes our day. That's what it's all about!
We have the Greatest Customers in the world. And thank you Lamont for providing a place to share the joy!
